Flash programming with Quick Start1.0
Merlin
Hi! I have some problems.
Up to now I used CW 4.0 for DSP56F805 and SDK libs for working with Flash Data Memory. But I was obliged to move my project to CW 7.0 and QuickStart 1.0.
Problem: How can I work with Flash Data Memory without SDK?
Thanks in advance!
Forums
QuickStart is not supported product and you will not find too many people who are familiar with it. I recommend going back to the person who gave you QuickStart and ask your question.
Since you are using CodeWarrior 7.0, you should utilize Processor Expert, which is based on the old SDK.
