Hi,I found MCF54418 TOWER board not use USBO_DP and USBO_DM? Why? is the USBO and USBH can not work in the same time? Thanks.
Did you ever find your answer?
I'm just starting to try to use the mcf54418 and was looking for some examples on using the USBO_DP and USBO_DM.
thanks,
Travis
