Anil Kumar Choudhury
Code Warrior HC08 Compiler Error: C2801: 'while' missing
Discussion created by Anil Kumar Choudhury on Jun 6, 2012
Latest reply on Jun 7, 2012 by CompilerGuru
I am using code warrior for first time.
I am facing this error during my code compilation:
This points to my this function first line.
I am not able to understand what is this about?
Code
void FlashEraseRestart(uint16 startAddr, uint16 size)
   FlashOpStatus status = FLASH_OP_OK;
   uint32 addr = startAddr;
   if(addr >= FLASH_START_ADDRESS)
      //Disable Interrupts. Access to flash during flash operations is not allowed
       asm
           SEI;
      for(addr = startAddr; addr < (startAddr + size - 1UL); addr += FLASH_SECTOR_SIZE)
          //Erase 1 sector at a time
          status = u8Flash_Erase((uint16)addr);
          if (FLASH_OP_OK != status)
             break;
      //Enable interrupts
      asm
          CLI;
   else
      status = FLASH_OP_ERROR;
   return status;
