issue about pressure sensor MPL3115A2
fengxiaojun1985
as  a virgin of  electrical design field, I was  confused in some fundamental problem.
      In my project , I use the pressure sensor(MPL3115A2) of your company. I know that pin 5 &6 is interrupt pin from the datasheet of mpl3115a2. But i do not know how to connect pin 5&6 with MCU .
      Pin 5&6 was connected to  any GPIO port of MCU,?or other specific port of MCU?
shivanagouda
Hi All,
I have downloaded the code for iMX6 SabreSD Board, But I am unable to locate the driver support for pressure sensor( Part no : MPL3115A2) in the entire kernel source code. Kindly provide the pointers so as to find the driver file for the same.
Dattatraya
edelm
