Hello
I would like to ask how to use the UART on the development kit kwikstik I tried to copy the code from the help, but the compiler says: "illegal implicit conversion from 'unsigned char' to 'void *'
how to do it?
Thank you for your answer
code for example:
struct { byte Header; byte Command; word Data; byte Checksum;} message;
void AS1_OnFullRxBuf(void) { word Received; byte err; err = AS1_RecvBlock((byte*)&message, sizeof(message), &Received); }
byte err;word Sent;void main(void){ message.Header = 0x55; message.Command = 0x01; message.Data = 0x0A0B; message.Checksum = message.Header + message.Command + (message.Data & 0x00ff) + (message.Data >> 8); err = AS1_SendBlock((byte*)&message, sizeof(message), &Sent); }
I have not used the example you are referring to. So, I cannot speak from experience. I noticed that you are using "byte" and "word". Neither of these are standard "C" types. Somewhere they must get defined.
Kevin
