When will processor expert be available for Kinetis K70F in MQX?
Question asked by Bob Fu on May 23, 2012
Latest reply on Jun 14, 2012 by Marek Vinkler
I assume there is a plan to add PE support for K70F. Does anyone know when it will be available?
If I generate some code (e.g., PWM with TimerUnit_LDD) using PE with K40, will the the generated code also work correctly in K70F? Or will the PWM timing be wrong?
bobf
