Dear All.
I want use to EEPROM.
but Datasheet is not Register.
Ex) EADDRHI, EADDRLO, EDATAHI, EDATALO
So, I have not been able to continue longer.
I think EEPROM use ...
initEEPROM
EPROT = 0x88; // EEPROM block can be programmed and erased
// EP = 0 => Protected sector Size 64bytes
// EPDIS = 1 => Protection disabled
// EPOPEN = 1 => Enabled for Program or Erase
ECLKDIV = 0x16;
// EDIV0~8 =22 =>
// PRDIV8 =0 => The oscillator clock is divided by 8 before feeding into the clock divider
// EDIVLD =0 => Register has been written
setEEPROM(unsigned int ADDR, unsigned int DATA)
ECMD = 0x20; //Word program
EADDR = ADDR;
EDATA = DATA;
When you do this, as will be seen....
I would like to know how to use EEPROM.
Register also...
Thank you...
