I'm trying to use the TRK-MPC5604B kit but every time I try to run/debug, I get the "Undetected. Disconnect/Connect USB cable. Click Refresh List. (FAQ #29)" error.
I have already tried to reinstall drivers, use the board on two other computers, use another cable and supply external power to the board.
I'm running out of ideas on how to solve this issue.
Did it happen with anyone else?
Does anyone have any suggestion on how to solve this issue?
Filipe Reis
Solved! Go to Solution.
Problem solved.
I've removed CodeWarrior "CW55xx_v2_7_SE" (version found on the dvd that came along with the kit) and installed CodeWarrior "CW55xx_v2_10_EVAL" .
Worked like a charm.
Problem solved.
