List of hotkey
List of hotkey
SylvainBortelle
Someone know how i can found a list of hotkeys used on CodeWarrior ?
Thank you.
J2MEJediMaster
Specialist I
You can start with the short list of shortcuts mentioned here. The article then points out where to go to find and change the rest of the shortcut key mappings.
---Tom
SylvainBortelle
Ok, thank you for your help.
But the hotkey mentioned on your link are for Eclipse no ?
For exemple Ctrl+Space don't work on my CodeWarrior IDE 5.9.0.
Good week.
CrasyCat
Specialist III
Hello
  You can check the key Bindings inside of CodeWarrior classic as follows:
    - Select Edit > Command and Key Bindings.
    - You should be able to see the Key bindings associated with the various menu commands.
Note that you can add or modify key bindings if you want to.
CrasyCat
SylvainBortelle
I searched a document who list hotkey, but the key binding inside CW is ok.
Thank you for your help.
Good day.
