We are using MQX 3.6.1 with a 52259 micro. I'd like to be able to access a USB stick that contains a file loaded from a PC. Is this possible to do without the use of MFS? We're having memory issues. Even though the system has external ram we're having compiler conflicts with MFS/USB and extended memory operation. The difference between light weight memory and not.
Solved! Go to Solution.
The short answer is you need MFS to read a MFS formatted USB drive/stick.
David
David
Hey there Douglas!
Any updates on the project?
Sorry for the delay, we'll be shortly working on your issue if there are still memory flaws!
Regards!
Monica
