I am trying to use the CDC Virtual Com Example on TWR-K60N512 and TWR-SER, with CW10.2 and MQX 3.8.
This is the cdc_vcom_twrk60n512 example project in the MQX 3.8 folder.
I can build and run in debug mode. But when I plug in a USB cable between the USB on TWR-SER board and the PC
USB, the PC does not see the USB device. Further debug it looks like the USB init task did not get executed by the RTOS and the RTOS is running in an idle loop task.
Is my problem the RTOS task structure no set up correctly?
VWong
Solved! Go to Solution.
Hi VWong,
The MQX3.8.1 update seems to have the virtual comm example working.
Please update and test. Alsom make sure you have most up-to-date "Terminal Untility" from www.pemicro.com with version 2.05 or newer.
David
Hi VWong,
David
Hey Vincent! How is that going? Still having problems?
Tech guys are working on the issue, thank you very much for waiting up...if any news, you'll let us know please?
Regards!
Monica
