Steve Church
Access violation error with P&E CASM08Z
Discussion created by Steve Church on Apr 30, 2012
Latest reply on Apr 30, 2012 by bigmac
I've been having problems with the CASM08Z assembler erroring out with an access violation message. I searched the net and found a few people having same problems but not resolved. The solution for me was that I had a comment line too long. Spreading it over two lines cured the problem. I thought I'd put this in the community in case someone else has a similar problem in the future. WINIde version 1.22 running on Windows XP SP2. I used an older version of assembler (V1.17) which worked and this showed a truncated listing file which is how I discovered the long line problem.
