9S08AW32 Newbie Question - Where to Start
Jack8421
Hi All,
I'm an electronics engineer by day and an enthusiast veteran Atmel AVR assembler programmer in my spare time. I'd like to master 9S08AW micros and have a couple of questions which you might be kind enough to help with:
1.  Is the following the correct development software for 9S08AW assembler coding ?
     CodeWarrior™ Development Studio for Microcontrollers V6.3
2.  Which is the cheapest programming hardware for 9S08AW ?
Many thanks
bigmac
Specialist III
Hello, and welcome to the forum.
For non-automotive use, you might use the later MC9S08AC family, rather than the 'AW series.
You might also consider purchasing a demonstration board that already has an on-board USB multilink interface for programming and debug.  The demonstration board is also fitted with a 64-pin socket for the MCU device.  By removal of the onboard device, and the fitting of a suitable lead, external programming and debug is possible.
Mac
raining
