SPI with variable clock pulses?
pittbull
Hello again,
I have a device with an SPI-like interface (master) that sends data words using 23 clock pulses. Therefore, I would like to know if the SPI module (S12SPI) is capable of handling this or can it only handle devices that send a multiple of 8 (16) clocks?
Thanks in advance,
pittbull
eeetee
hi:
the shift registers are not configurable. you would have to do it with some bit-banging code.
regards,
ed
pittbull
Thank you very much. I'll try it this way.
