I'm trying to experiment with _time_get_elapsed_ticks() and _time_get_elapsed().
In the following code the the values in the pointers aren't getting adjusted.
I.e. The value(s) are garbage and are unchanged.
I presume I'm doing something wrong or haven't set something correctly in the bsp/psp. But the Reference Manual doesn't state that I need to enable anything specific in the user_config.h file.
void nill_task (uint_32 initial_data){ MQX_TICK_STRUCT_PTR tick_time_ptr; TIME_STRUCT_PTR ms_time_ptr; while (1) { _time_get_elapsed_ticks(tick_time_ptr); _time_get_elapsed(ms_time_ptr); __no_operation(); _time_delay(1023); }}
Any suggestions?
Solved! Go to Solution.
Worked it out.
The code should read.
void nill_task (uint_32 initial_data){ MQX_TICK_STRUCT tick_time; TIME_STRUCT ms_time; while (1) { _time_get_elapsed_ticks(&tick_time); _time_get_elapsed(&ms_time); __no_operation(); _time_delay(1023); }}
Worked it out.
