After install CW 10.2 and MQX 3.8 successfully, I tried to install MQX extension for CW and failed. Error log is attached.
I am using Windows 7-32bit and have JRE 6 update 31 installed.
Now I can not use MQX 3.8 project wizard in CW 10.2
Does anyone know what happened and how to resolve this? Thank you.
Solved! Go to Solution.
Tim,
Because MQX 3.8.0 had been released before the CW 10.2 was, there is a bug in the installer script which sometimes may lead to the error you are facing now. Symptoms of this error is a strange message you got in your log "Expected timestamp 1334210273179 but was 1334210273179" - timestamps are equal, however Eclipse treates them as if the were not.
Anyway, you can find fixed scripts in the attachment. Just replace the original ones in the MQX CW 10.2 extension folder (<MQX 3.8.0 installation folder>\tools\codewarrior_extensions\CW MCU v10.2\) and try to install plug-ins once again using new scripts.
Best Regars,
Marcin
I have CW PA 10.2.1 installed. Is there MQX 3.8 TAD support for this installation?
Tim,
Best Regars,
Marcin
It worked! Thank you!
