Philippe Vallee
CodeWarrior 10.2 Syntax coloring
Discussion created by Philippe Vallee on Apr 11, 2012
Latest reply on Apr 12, 2012 by Philippe Vallee
Syntax coloring is not working for assembly sources (*.asm) , the keys, variables, and others have the same color, but not the right defined in the Assembly syntax coloring menu. Only the label use the right color. Same for assembly code in C source. System run under XP SP3.
