Piotr Piwko
Problem with TBM
Discussion created by Piotr Piwko on Feb 19, 2006
Latest reply on Feb 21, 2006 by Piotr Piwko
I would like to use Timebase Module (TBM) in GP32. I set timebase rate to 1Hz but TBM generates too many tamebase interrupt. Please tell me what do I wrong. This is my code in CW08:
/* TBM interrupt handle */
void interrupt 16 tbm_interrupt()
if(LED_PIN == 1)
led_off();
else
led_on();
void main(void)
EnableInterrupts; // Enable interrupts
LED_DDR = 1; // Led pin as output
/* TBM (Timebase Module) */
TBCR_TBON = 0; // Disable TBM
TBCR_TACK = 1;
// Timebase rate to 1Hz
TBCR_TBR2 = 0; TBCR_TBR1 = 0; TBCR_TBR0 = 0;
TBCR_TBIE = 1; // Enable timebase interrupt
TBCR_TBON = 1; // Enable TBM
for(;:smileywink: {
__RESET_WATCHDOG(); // Watchdog
Thank you for your time
