Understanding the Linker (lcf) File
Jiun_Yong
Can someone please direct me to a comprehensive guide on the various instructions that can be used in the lcf file.
I have just started on a Kinetis project, having previously worked on HCS12, so this is unfamiliar territory for me. I have gleaned a few things from example programs, but am looking for a proper guide. The project will require a customised bootloader, to be backwardly compatible with existing products.
Many thanks
Steve
Thommi_Tulpe
you can finde a good guide under:
C:\Program Files\Freescale\CW MCU v10.1\MCU\Help\PDF\MCU_Kinetis_Compiler.pdf
Have a look at chapter 12
Best Regards
Thomas
Thommi_Tulpe
Best Regards
Thomas
Jiun_Yong
Thanks very much Thomas, that's just what I was looking for.
Just a case of knowing where to look in the documentation.
No worries!
emh203
If you open codewarrior 10, look under help I believe there is a good section on the syntax.
