Lucas Santana
trying to make a program using C
Discussion created by Lucas Santana on Apr 2, 2012
Latest reply on Apr 3, 2012 by bigmac
Hi everyone, im trying to make the same program from assembly to C
By the way im using the microcontroler MC68HC908QY4
My program in assembly is this.
DELAY: DS 1
MyCode:     SECTION
main:
_Startup:
CONFIGURATIONS:
                  LDA  #$19
                  STA CONFIG1 ;no COP; no LVI; +5V
                  LDA #0
                  STA CONFIG2   ;3,2MHZ ; no extern interruption; no RESET;
                  LDA #$38
                  STA DDRA    ;PTA5 , PTA4 E PTA3 outputs
INI:
GREEN:
              LDA #$20
              STA PTA   ;turn on
              BSR D1SEC
YELLOW:
                    LDA #$10
                    STA PTA   ; turn on
                     BSR D1SEC
RED:
                        LDA #$08
                        STA PTA  ;turn on
                         BSR D1SEC
                        BRA INI
D1SEC:
              LDA #100
              STA DELAY
D10MILI:
                LDX #100
D100MICRO:
                      LDA #80
 LOOP:
              DECA
              BNE LOOP
                DECX
                BNE D100MICRO
                DEC DELAY
                BNE D10MILI
              RTS
              END
This program uses three LEDs when choosing each output (PTA3, PTA4, PTA5), the LED is turned on, for one second, the loop D1SEC, creates a delay of 1 second.
Here is the same program but with two loops now, each loop will make the leds be turned on with diferent times. There are some minor changes now, but the program as i said is the same. The program with assembly is working fine!
            INCLUDE 'derivative.inc'
            XDEF _Startup, main
MY_ZEROPAGE: SECTION  SHORT
TIMESIGNAL: DS 1
DELAY: DS 2
MyCode:     SECTION
main:
_Startup:
CONFIGURATIONS:
                  MOV #$19, CONFIG1
                  MOV #0, CONFIG2
                  MOV #$38, DDRA
                  MOV #$1, PTAPUE
INI:
READKEY:
          LDA PTA ;A=X X GREEN   YELLOW   RED   X X CH0
          AND #1; #1=0 0        0              0              0      0 0   1
          BNE  TEMP1 ;A=0000000CH0
TEMP0:
GREEN:
              MOV #$20, PTA
              MOV #5,TIMESIGNAL ;5SEC
LGREEN:
              BSR D1SEG
              DEC TIMESIGNAL
              BNE LGREEN
YELLOW:
                    MOV #$10, PTA
                    MOV #2, TIMESIGNAL ;2SEC
LYELLOW:
              BSR D1SEC
              DEC TIMESIGNAL
              BNE LYELLOW
RED:
                        MOV #$08, PTA
                       MOV #4, TIMESIGNAL ;4SEC
LRED:
              BSR D1SEC
              DEC TIMESIGNAL
              BNE LRED
                        BRA INI
TEMP1:
GREEN1:
              MOV #$20, PTA
              MOV #4,TIMESIGNAL ;4SEC
LGREEN1:
              BSR D1SEC
              DEC TIMESIGNAL
              BNE LGREEN1
YELLOW1:
                    MOV #$10, PTA
                    MOV #1, TIMESIGNAL ;1SEC
LYELLOW1:
              BSR D1SEC
              DEC TIMESIGNAL
              BNE LYELLOW1
RED1:
                        MOV #$08, PTA
LRED1:
              BSR D1SEC
              DEC TIMESIGNAL
              BNE LRED1
                        BRA INI
D1SEC:
               MOV #100, DELAY+1
D10MILI:
                 MOV #100, DELAY
D100MICRO:
                      LDA #80
 LOOP:
              DECA
              BNE LOOP
                DEC DELAY
                BNE D100MICRO
                DEC DELAY+1
                BNE D10MILI
              RTS
              END
And now here is my problem, when im trying to make the same code (using the code with 2 loops), it gives me an error in line 19)
#include <hidef.h> /* for EnableInterrupts macro */
#include "derivative.h" /* include peripheral declarations */
#define RED 0x08
#define GREEN 0x20
#define YELLOW 0x10
#define DLY5 40000
#define DLY2 16000
#define DLY4 32000
#define DLY1 8000
void temporiza( unsigned long int);
void main(void)
  CONFIG1=0x19;
  CONFIG2=0x00;
  DDRA=0x38;
  PTAPUE=0x01;
if(!PTA_ PTA0)                          // MY PROBLEM IS IN THIS LINE
for( ;; )
PTA=GREEN;
temporiza(DLY5);
PTA=YELLOW;
temporiza(DLY2);
PTA=RED;
temporiza(DLY4);
else
PTA=GREEN;
temporiza(DLY4);
PTA=YELLOW;
temporiza(DLY1);
PTA=RED;
temporiza(DLY2);
void temporiza( unsigned long int delay)
while(delay--);
Im trying to make my if works.
Someone can help me please?
Thanks a lot for your time.
