Shahzad Malik
MCF54453 Clocking Module Question
Discussion created by Shahzad Malik on Mar 28, 2012
Latest reply on Mar 29, 2012 by TomE
Just a quick question about the pin connections on the clocking module:
What do you suggest I do with the PLLTEST pin (D15)? I am using the eval kit schematic as a reference however this pin is just floating.... Is this correct?
Also should I tie the TEST pin (ab20) to ground?
