How to add N number of ITEMS in D4D_MENU(K60 eGUI)
SUNU
Hiii,
 I need to add "N" number of items in d4d_menu screen for k60 egui .I can added limited number of item in user menu screen like D4D_DECLARE_MENU_ITEM_FULL( "file1.mp3",&bmp_music_notes,&screen_musicplayer)
                     D4D_DECLARE_MENU_ITEM_FULL( "file2.mp3",&bmp_music_notes,&screen_musicplayer)
                     D4D_DECLARE_MENU_ITEM_FULL( "file3.mp3",&bmp_music_notes,&screen_musicplayer)
                     D4D_DECLARE_MENU_ITEM_FULL( "file4.mp3",&bmp_music_notes,&screen_musicplayer) it in globaly decleared ,So i can't use for and while loop here what i do for this.I attached one example in this mail.
Gargy
 the solution is simple.
Declare the MENU object in RAM, and then dynamically alloc memory N*sizeof(D4D_MENU_ITEM). And fill up this structures.
Finally put pointer on this array to MENU object structure (pItems) and update posCnt also in same menu structure.
Gargy
SUNU
I am beginner in eGui. I don't know where i should call the menu object structure.I declared like this
D4D_DECLARE_STD_RMENU_AUTOSIZE_BEGIN_INRAM(scrfilemanger_menu, "List Of Files" , FONT_ARIAL12B, 0,30 , 200, 150, 4, FONT_ARIAL12, FONT_ARIAL12, NULL,ScrMenu_OnClick)
D4D_DECLARE_RMENU_END_INRAM(scrfilemanger_menu) ,i don't know in where call the "pItems" structure(OnInit(),OnMain()) .Please explain with any example.
Gargy
 anywhere, out of the D4D_MENU code is running.
So all you mentioned functions are OK.
just create the new arrays of the MENU_ITEM  structures and update pointer on this array to the MENU object as I describe in previous message.
Gargy
SUNU
I Don't know how to do this ,I did like this
char str[10][10]={"f1","f2","f3","f4","f5"};
//Screen "Main" function called periodically in each D4D_poll runs
static void ScreenFilemanager_OnMain()
           D4D_MENU_ITEM* Menu[10];
           D4D_MENU* pMenu=D4D_GET_MENU(&scrfilemanger_menu);
            int i;
            D4D_MENU_INDEX  j=0;
           // pMenu->posCnt=0;
            for(i=0;i<5;i++)
                //D4D_MenuSetIndex((D4D_OBJECT*)&scrfilemanger_menu,j);
                strcpy(Menu[i]->text.pText,str[i]);
                Menu[i]->pIcon=NULL;
                Menu[i]->pUser=NULL;
                pMenu->pItems=Menu[i];
                pMenu->posCnt++;
               //j++
When i running the code the filemanager screen stuck  and debugger come out of kernal.I don't know how to do this,What change i should make this code.
Gargy
 you are close, but not in finish line :smileyhappy:
Look at this:
           static D4D_MENU_ITEM* Menu[10];
            int i;
            D4D_MENU_INDEX  j=0;
           // pMenu->posCnt=0;
            for(i=0;i<5;i++)
nu,j);
                //strcpy(Menu[i]->text.pText,str[i]);
                Menu[i]->text.pText = str[i];
                Menu[i]->text.buffSize = 10;
                Menu[i]->text.str_properties= NULL;  // In menu is used common text properties settings
                Menu[i]->text.printLen = 10;
                Menu[i]->text.printOff = 0;
               //j++
      pMenu->posCnt = 5;
      pMenu->pItems=&Menu[0];
I hope this helps, you have to keep in mind that the menu item storage that you will create has to be keep in memory (static).
Gargy
michaelsthomas
I have a similar need to create dynamic menu items.  I thought I understood this chain of posts, but when I run the code and switch to the menu screen, my debugger halts on a hardware error.
Nouchi
Senior Contributor II
 And, I will add :
static void ScreenFilemanager_OnMain(){static D4D_MENU_ITEM* Menu[10];D4D_MENU* pMenu=D4D_GET_MENU(&scrfilemanger_menu);int i;D4D_MENU_INDEX  j=0;  for(i=0;i<5;i++)  {      Menu[i]->text.pText = str[i];      Menu[i]->text.buffSize = 10;      Menu[i]->text.str_properties= NULL;  // In menu is used common text properties settings      Menu[i]->text.printLen = 10;      Menu[i]->text.printOff = 0;      Menu[i]->pIcon=NULL;      Menu[i]->pUser=NULL;  }  Menu[i]->text.pText = NULL;  Menu[i]->pIcon = NULL;  pMenu->posCnt = 5;  pMenu->pItems=&Menu[0];   }
to end D4D_MENU_ITEM list
Gargy
 you right, Good point.
Gargy
