Mike Solem
56F8300 "CCS not present"
Discussion created by Mike Solem on Feb 10, 2006
Latest reply on Nov 8, 2010 by Renjith G
I've installed CodeWarrior for the DSP 56800. I've also recently installed the update for version 7.3. When I try to debug the code, I get this error:
"CCS: Command converter not present"
I'm using a laptop, with a PCMCIA parallel port. I've used this PCMCIA card before, on a similar laptop, with the same 56F8300Demo board, and it worked fine.
Any ideas on what I can try next?
Mike
