Ron Wilson
synchronizing AtoD with PWM on S12XE
Discussion created by Ron Wilson on Mar 14, 2012
Latest reply on Mar 16, 2012 by Ron Wilson
We are using an S12XEQ384
Looking at the documentation, the only way I can determine to synchronize anything to the PWM is to connect the PWM outputs to inputs on other pins.
Am I overlooking some other option?
Our hardware design did not anticipate a need for connecting PWM outputs to inputs on other pins, so the hardware people would have to relase a design revision and order new prototypes, so a software solution is strongly prefered.
