Hi All,
I am using K60N512 and I want to use PE to generate code for DCA1_OUT. The PE does not allow me to generate code for Methods related to the buffer. How do I enable this feature (as the Kinetis DAC supports data buffers) ?
Mohsin
Solved! Go to Solution.
Its availiable in advance mode.
