p4080ds and 10g copper ethernet
simon_duboue
Hello everybody,
Does someone of you already manage to get a 10gigabit connection through the ethernet copper interface with the p4080ds?
Even with the freescale SDK, I can not establish a connection between my p4080 board and a dedicated computer with an ethernet card and a linux.
I know my question is very large but I can enter more in the details if someone of you works on this specific subject.
I already work on the SERDES errata 8, changing the hwconfig and trying several RCW without success.
I dream of the day during which I will get a ping...
Any suggestion on how to process is greatly appreciated!
Simon
brianrzycki
I just spoke to one of our team members in a test lab.  They have verified 10g copper working on their setup. I asked them to give me the u-boot log and hwconfig variable. The u-boot is an internal build likely based off SDK 1.2.  The important thing is to note the rcw and hwconfig settings.
Also, what slot is the 10g XAUI riser connected to? Slot 5 corresponds to FM1@TGEC1 and Slot 4 corresponds to FM2@TGEC1.
I recommend trying to ping directly from u-boot before loading Linux. It can help narrow down where the problem occurs.
U-Boot 2011.06-rc2-00009-g719876a-dirty (May 18 2012 - 13:45:22)
CPU0:  P4080E, Version: 2.0, (0x82080020)
Core:  E500MC, Version: 2.0, (0x80230020)
Clock Configuration:
      CPU0:1499.985 MHz, CPU1:1499.985 MHz, CPU2:1499.985 MHz, CPU3:1499.985 MHz,
      CPU4:1499.985 MHz, CPU5:1499.985 MHz, CPU6:1499.985 MHz, CPU7:1499.985 MHz,
      CCB:799.992 MHz,
      DDR:649.994 MHz (1299.987 MT/s data rate) (Asynchronous), LBC:99.999 MHz
      FMAN1: 599.994 MHz
      FMAN2: 599.994 MHz
      PME:   399.996 MHz
L1:    D-cache 32 kB enabled
      I-cache 32 kB enabled
Board: P4080DS, Sys ID: 0x17, Sys Ver: 0x01, FPGA Ver: 0x0c, vBank: 4
36-bit Addressing
Reset Configuration Word (RCW):
      00000000: 105a0000 00000000 1e18181e 0000cccc
      00000010: 38424400 3c3c2000 fe800000 61000000
      00000020: 00000000 00000000 00000000 008b0000
      00000030: 00000000 00000000 00000000 00000000
SERDES Reference Clocks: Bank1=100MHz Bank2=125MHz Bank3=125MHz
I2C:   ready
SPI:   ready
DRAM:  Initializing....using SPD
Detected UDIMM EBJ21EE8BAFA-DJ-E
CS2 is disabled.
CS3 is disabled.
Address hashing enabled.
CS2 is disabled.
CS3 is disabled.
2 GiB left unmapped
   DDR: 4 GiB (DDR3, 64-bit, CL=9, ECC on)
      DDR Controller Interleaving Mode: cache line
      DDR Chip-Select Interleaving Mode: CS0+CS1
Testing 0x00000000 - 0x7fffffff
Testing 0x80000000 - 0xffffffff
Remap DDR 2 GiB left unmapped
POST memory PASSED
Flash: 128 MiB
L2:    128 KB enabled
Corenet Platform Cache: 2048 KB enabled
SRIO1: disabled
SRIO2: disabled
MMC:  FSL_ESDHC: 0
EEPROM: Invalid ID (ff ff ff ff)
PCIe1: Root Complex, no link, regs @ 0xfe200000
PCIe1: Bus 00 - 00
PCIe2: Root Complex, no link, regs @ 0xfe201000
PCIe2: Bus 01 - 01
PCIe3: Root Complex, no link, regs @ 0xfe202000
PCIe3: Bus 02 - 02
In:    serial
Out:   serial
Err:   serial
Net:   Fman1: Uploading microcode version 101.8.0
FM1@DTSEC2 connected to Vitesse VSC8244
FM1@TGEC1 connected to Teranetics TN2020
Fman2: Uploading microcode version 101.8.0
FM2@DTSEC3 connected to Vitesse VSC8234
FM2@DTSEC4 connected to Vitesse VSC8234
FM2@TGEC1 connected to Teranetics TN2020
FM1@DTSEC2, FM1@TGEC1, FM2@DTSEC3, FM2@DTSEC4, FM2@TGEC1
hwconfig=fsl_ddr:ctlr_intlv=cacheline,bank_intlv=cs0_cs1,addr_hash=true
ratnarajmirgal
Hi All,
I'm working with 2- p4080ds systems, both systems are identical. below is my u-boot env.
U-Boot 2010.12-00007-g4114d25 (Jan 26 2011 - 22:35:21)
  CCB:799.992 MHz,
  FMAN1: 599.994 MHz
  FMAN2: 599.994 MHz
  PME: 399.996 MHz
Board: P4080DS, Sys ID: 0x17, Sys Ver: 0x01, FPGA Ver: 0x0c, vBank: 0
36-bit Addressing
  00000000: 105a0000 00000000 1e1e181e 0000cccc
  00000010: 40464000 3c3c2000 fe800000 61000000
  00000020: 00000000 00000000 00000000 008b6000
I2C: ready
Detected UDIMM(s)
Detected UDIMM(s)
CS2 is disabled.
CS3 is disabled.
CS2 is disabled.
CS3 is disabled.
2 GiB left unmapped
  DDR: 4 GiB (DDR3, 64-bit, CL=9, ECC off)
POST memory PASSED
FLASH: 128 MiB
L2: 128 KB enabled
SRIO1: disabled
SRIO2: disabled
MMC: FSL_ESDHC: 0
EEPROM: NXID v0
PCIe1: Bus 00 - 00
PCIe2: disabled
PCIe3: Root Complex, x1, regs @ 0xfe202000
  02:00.0 - 1095:3132 - Mass storage controller
PCIe3: Bus 01 - 02
Video: No radeon video card found!
In: serial
Out: serial
Err: serial
Net: Fman: Uploading microcode version 101.8.0.
Dtsec: PHY is Vitesse VSC8244 (fc6c2)
Dtsec: PHY is Vitesse VSC8234 (fc623)
FM1@DTSEC2, FM2@DTSEC1, FM2@DTSEC2, FM2@DTSEC3, FM2@DTSEC4, FM2@TGEC1
Hit any key to stop autoboot: 0
=> printenv
baudrate=115200
bdev=sda3
bootargs=console=ttyS0,115200 ip=10.137.108.232:10.137.108.165:10.137.108.129:255.255.255.128::eth0:none root=/dev/nfs rw nfsroot=10.137.10
8.165:/tftpboot/loads/board1/rootfs
bootcmd=tftp $loadaddr $bootfile; tftp $fdtaddr $fdtfile; bootm $loadaddr - $fdtaddr
bootdelay=5
bootfile=board1/fsl_p4080-uImage-WR4.3.0.0_cgl
c=ffe
consoledev=ttyS0
dir=b25229/01-20
eth=FM1@DTSEC2
eth1addr=00:04:9F:02:21:2E
eth2addr=00:04:9F:02:21:2F
eth3addr=00:04:9F:02:21:30
eth4addr=00:04:9F:02:21:31
eth5addr=00:04:9F:02:21:32
eth6addr=00:04:9F:02:21:33
eth7addr=00:04:9F:02:21:34
eth8addr=00:04:9F:02:21:35
eth9addr=00:04:9F:02:21:36
ethact=FM1@DTSEC2
ethaddr=00:04:9F:02:21:2D
fdtaddr=c00000
fdtfile=board1/p4080ds_36b.dtb
fileaddr=1000000
filesize=3DECE9
fman_ucode=0xFEF000000ULL
gatewayip=10.137.108.129
hwconfig=fsl_ddr:ctlr_intlv=cacheline,bank_intlv=cs0_cs1,ecc=off
ipaddr=10.137.108.232
loadaddr=1000000
netdev=eth0
netmask=255.255.255.128
rootpath=/tftpboot/loads/board1/rootfs
serverip=10.137.108.165
stderr=serial
stdin=serial
stdout=serial
uboot=u-boot.bin
ubootaddr=0xeff80000
Environment size: 1182/8188 bytes
After changing hwconfig to "fsl_ddr:ctlr_intlv=cacheline,bank_intlv=cs0_cs1,ecc=off", (serdes config to make bank2/3 power-on). I started seeing 10g card in slot4 FM2@TGEC1.
for testing purpose I connected both 10g to local lan, keeping rest of the interfaces disconnected. (not trying to boot from 10g, just checking connectivity), however I could not see any response on 10g interface.
=> ping 10.137.108.231
FM1@DTSEC2 Waiting for PHY auto negotiation to complete..... TIMEOUT !
FM2@DTSEC1 Waiting for PHY auto negotiation to complete..... TIMEOUT !
FM2@DTSEC2 Waiting for PHY auto negotiation to complete..... TIMEOUT !
FM2@DTSEC3 Waiting for PHY auto negotiation to complete..... TIMEOUT !
FM2@DTSEC4 Waiting for PHY auto negotiation to complete..... TIMEOUT !
Using FM2@TGEC1 device
ping failed; host 10.137.108.231 is not alive
Please help me understand if I'm missing any configuration?
TIA.
matthewh
Was curious if this issue was ever resolved?
Is you 10G link connected to a 10G capable interface?  Some of the 10G copper PHY's will only connect at 10G with the XAUI interface on the 4080.
mattsm
What does ethtool say the link status is?
-M
leonidravich
ethtool fm2-10g
Settings for fm2-10g:
        Supported ports: [ ]
        Supported link modes:
        Supports auto-negotiation: No
        Advertised link modes:  Not reported
        Advertised auto-negotiation: No
        Speed: Unknown! (10000)
        Duplex: Full
        Port: MII
        PHYAD: 0
        Transceiver: external
        Auto-negotiation: on
        Current message level: 0xffffffff (-1)
        Link detected: yes
it uses linux generic 10G driver and it looks like it sets link status hard coded
so I do not think it is an indication.
mattsm
Can you share a boot log? Also your u-boot environment?
-M
leonidravich
U-Boot 2010.12-00001-g612800e (Jan 28 2011 - 22:20:46)
       CPU0:1199.988 MHz, CPU1:1199.988 MHz, CPU2:1199.988 MHz, CPU3:1199.988 MHz,
       CPU4:1199.988 MHz, CPU5:1199.988 MHz, CPU6:1199.988 MHz, CPU7:1199.988 MHz,
       CCB:599.994 MHz,
       DDR:599.994 MHz (1199.988 MT/s data rate) (Asynchronous), LBC:74.999 MHz
       FMAN1: 449.996 MHz
       FMAN2: 449.996 MHz
       PME:   299.997 MHz
36-bit Addressing
       00000000: 4c580000 00000000 18185218 0000cccc
       00000010: 4046400f 3c3c2000 fe800000 61000000
I2C:   ready
Detected UDIMM(s)
Detected UDIMM(s)
Not enough bank(chip-select) for CS0+CS1+CS2+CS3 on controller 0, force non-interleaving!
Not enough bank(chip-select) for CS0+CS1+CS2+CS3 on controller 1, force non-interleaving!
Addess hashing enabled.
    DDR: 2 GiB (DDR3, 64-bit, CL=8, ECC on)
Remap DDR
POST memory PASSED
FLASH: 128 MiB
L2:    128 KB enabled
SRIO1: disabled
SRIO2: disabled
MMC:  FSL_ESDHC: 0
EEPROM: NXID v0
PCIe1: Bus 00 - 00
PCIe2: disabled
PCIe3: Bus 01 - 01
In:    serial
Out:   serial
Err:   serial
Net:   Fman: Uploading microcode version 92.8.0.
FM1@DTSEC2, FM2@TGEC1
WARNING: adjusting available memory to 30000000
## Booting kernel from Legacy Image at e8020000 ...
   Image Name:   Linux-2.6.34.6-00001-g612800e
   Image Type:   PowerPC Linux Kernel Image (gzip compressed)
   Data Size:    3355037 Bytes = 3.2 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at e9300000 ...
   Image Name:   uboot ext2 ramdisk rootfs
   Image Type:   PowerPC Linux RAMDisk Image (gzip compressed)
   Data Size:    19443311 Bytes = 18.5 MiB
## Flattened Device Tree blob at e8800000
   Booting using the fdt blob at 0xe8800000
   Uncompressing Kernel Image ... OK
   Loading Ramdisk to 2ed75000, end 2ffffe6f ... OK
   Loading Device Tree to 00ff3000, end 00fff444 ... OK
Using P4080 DS machine description
Memory CAM mapping: 256/256/256 Mb, residual: 1280Mb
Linux version 2.6.34.6-00001-g612800e (builder@builder-desktop) (gcc version 4.5.1 (Sourcery G++ Lite 2010.09-55) ) #1 SMP Fri Jan 28 22:25:52 CST 2011
Found initrd at 0xeed75000:0xeffffe6f
No /soc@ffe000000/qman@318000 property 'fsl,qman-fqd', using lmb_alloc(0000000000200000)
No /soc@ffe000000/qman@318000 property 'fsl,qman-pfdr', using lmb_alloc(0000000001000000)
Qman ver:0a01,01,01
No /soc@ffe000000/bman@31a000 property 'fsl,bman-fbpr', using lmb_alloc(0000000001000000)
Bman ver:0a02,01,00
pme: No /soc@ffe000000/pme@316000 property 'fsl,pme-pdsr', using lmb_alloc(0x0000000001000000)
pme: No /soc@ffe000000/pme@316000 property 'fsl,pme-sre', using lmb_alloc(0x0000000000a00000)
CPU maps initialized for 1 thread per core
bootconsole [udbg0] enabled
setup_arch: bootmem
Found FSL PCI host bridge at 0x0000000ffe200000. Firmware bus number: 0->0
PCI host bridge /pcie@ffe200000  ranges:
MEM 0x0000000c00000000..0x0000000c1fffffff -> 0x00000000e0000000
  IO 0x0000000ff8000000..0x0000000ff800ffff -> 0x0000000000000000
/pcie@ffe200000: PCICSRBAR @ 0xdf000000
Found FSL PCI host bridge at 0x0000000ffe202000. Firmware bus number: 0->0
PCI host bridge /pcie@ffe202000  ranges:
MEM 0x0000000c40000000..0x0000000c5fffffff -> 0x00000000e0000000
  IO 0x0000000ff8020000..0x0000000ff802ffff -> 0x0000000000000000
/pcie@ffe202000: PCICSRBAR @ 0xdf000000
P4080 DS board from Freescale Semiconductor
arch: exit
Zone PFN ranges:
  DMA      0x00000000 -> 0x00030000
  Normal   empty
  HighMem  0x00030000 -> 0x00080000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
    0: 0x00000000 -> 0x00080000
MMU: Allocated 1088 bytes of context maps for 255 contexts
PERCPU: Embedded 9 pages/cpu @c200a000 s16276 r8192 d12396 u65536
pcpu-alloc: s16276 r8192 d12396 u65536 alloc=16*4096
pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 520192
Kernel command line: root=/dev/sda3 rw console=ttyS0,115200
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 1991448k/2097152k available (6780k kernel code, 105704k reserved, 236k data, 423k bss, 252k init)
Kernel virtual memory layout:
  * 0xfff67000..0xfffff000  : fixmap
  * 0xffc00000..0xffe00000  : highmem PTEs
  * 0xffbd8000..0xffc00000  : early ioremap
  * 0xf1000000..0xffbd8000  : vmalloc & ioremap
Hierarchical RCU implementation.
RCU-based detection of stalled CPUs is enabled.
NR_IRQS:512 nr_irqs:512
mpic: Setting up MPIC " OpenPIC  " version 1.2 at ffe040000, max 8 CPUs
mpic: ISU size: 256, shift: 8, mask: ff
mpic: Initializing for 256 sources
clocksource: timebase mult[6aaaf09] shift[22] registered
Console: colour dummy device 80x25
Mount-cache hash table entries: 512
mpic: requesting IPIs...
Processor 1 found.
Processor 2 found.
Processor 3 found.
Processor 4 found.
Processor 5 found.
Processor 6 found.
Processor 7 found.
Brought up 8 CPUs
e500 family performance monitor hardware support registered
PCI: Probing PCI hardware
pci 0000:00:00.0: ignoring class b20 (doesn't match header type 01)
pci 0000:00:00.0: PCI bridge to [bus 01-ff]
pci 0001:02:00.0: ignoring class b20 (doesn't match header type 01)
pci 0001:02:00.0: PCI bridge to [bus 03-ff]
pci 0000:00:00.0: PCI bridge to [bus 01-01]
pci 0000:00:00.0:   bridge window [io  0xffbeb000-0xffbfafff]
pci 0000:00:00.0:   bridge window [mem 0xc00000000-0xc1fffffff]
pci 0000:00:00.0:   bridge window [mem pref disabled]
pci 0001:02:00.0: PCI bridge to [bus 03-03]
pci 0001:02:00.0:   bridge window [io  0xffbd9000-0xffbe8fff]
pci 0001:02:00.0:   bridge window [mem 0xc40000000-0xc5fffffff]
pci 0001:02:00.0:   bridge window [mem pref disabled]
bio: create slab <bio-0> at 0
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Bman err interrupt handler present
Bman portal at f1050000:f1056000 (0)
Bman portal initialised, cpu 0
Bman portal at f1060000:f105a000 (1)
Bman portal initialised, cpu 1
Bman portal at f1068000:f105e000 (2)
Bman portal initialised, cpu 2
Bman portal at f1070000:f1066000 (3)
Bman portal initialised, cpu 3
Bman portal at f1078000:f106e000 (4)
Bman portal initialised, cpu 4
Bman portal at f1080000:f1076000 (5)
Bman portal initialised, cpu 5
Bman portal at f1088000:f107e000 (6)
Bman portal initialised, cpu 6
Bman portal at f1090000:f1086000 (7)
Bman portal initialised, cpu 7
Bman portal at f1098000:f108e000 (-1)
Bman portal at f10a0000:f1096000 (-1)
Bman: reserved bpid 0, seeded 256 items
Qman err interrupt handler present
Qman portal at f10a8000:f109e000 (0:0,v0101)
Qman portal initialised, cpu 0
Qman portal at f10b0000:f10a6000 (1:1,v0101)
Qman portal initialised, cpu 1
Qman portal at f10b8000:f10ae000 (2:2,v0101)
Qman portal initialised, cpu 2
Qman portal at f10c0000:f10b6000 (3:3,v0101)
Qman portal initialised, cpu 3
Qman portal at f10c8000:f10be000 (4:4,v0101)
Qman portal initialised, cpu 4
Qman portal at f10d0000:f10c6000 (5:5,v0101)
Qman portal initialised, cpu 5
Qman portal at f10d8000:f10ce000 (6:6,v0101)
Qman portal initialised, cpu 6
Qman portal at f10e0000:f10d6000 (7:7,v0101)
Qman portal initialised, cpu 7
Qman portal at f10e8000:f10de000 (-1:8,v0101)
Qman portal at f10f0000:f10e6000 (-1:9,v0101)
Qman driver initialised
Switching to clocksource timebase
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 18987k freed
Setting Freescale static PAMU/IOMMU configuration
Freescale PowerQUICC MII Bus: probed
mdio_bus mdio@ffe4e1120: /soc@ffe000000/fman@400000/mdio@e1120/p4080ds-mdio0 has invalid PHY address
mdio_bus mdio@ffe4e1120: /soc@ffe000000/fman@400000/mdio@e1120/p4080ds-mdio1 has invalid PHY address
mdio_bus mdio@ffe4e1120: /soc@ffe000000/fman@400000/mdio@e1120/p4080ds-mdio2 has invalid PHY address
mdio_bus mdio@ffe4e1120: /soc@ffe000000/fman@400000/mdio@e1120/p4080ds-mdio3 has invalid PHY address
Freescale XGMAC MDIO Bus: probed
mdio_bus mdio: /soc@ffe000000/fman@400000/mdio@f1000/p4080ds-xmdio1 has invalid PHY address
mdio_bus mdio: /soc@ffe000000/fman@400000/mdio@f1000/p4080ds-xmdio3 has invalid PHY address
Freescale P4080DS MDIO Bus: probed
audit: initializing netlink socket (disabled)
type=2000 audit(0.368:1): initialized
highmem bounce pool size: 64 pages
NTFS driver 2.1.29 [Flags: R/O].
JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
msgmni has been set to 1366
alg: No test for cipher_null (cipher_null-generic)
alg: No test for ecb(cipher_null) (ecb-cipher_null)
alg: No test for digest_null (digest_null-generic)
alg: No test for compress_null (compress_null-generic)
alg: No test for stdrng (krng)
io scheduler noop registered
Generic non-volatile memory driver v1.1
ePAPR hypervisor byte channel console driver
ehv-bc: no hypervisor found
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0xffe11c500 (irq = 36) is a 16550A
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0xffe11c600 (irq = 36) is a 16550A
serial8250.0: ttyS2 at MMIO 0xffe11d500 (irq = 37) is a 16550A
serial8250.0: ttyS3 at MMIO 0xffe11d600 (irq = 37) is a 16550A
brd: module loaded
loop: module loaded
nbd: registered device at major 43
Freescale hypervisor management driver
fsl-hv: no hypervisor found
st: Version 20081215, fixed bufsize 32768, s/g segs 256
fe8000000.flash: Found 1 x16 devices at 0x0 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
fe8000000.flash: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
RedBoot partition parsing not available
fsl_espi ffe110000.spi: at 0xf11ba000 (irq = 53)
m25p80 spi32766.0: s25sl12801 (16384 Kbytes)
Creating 4 MTD partitions on "spi32766.0":
0x000000000000-0x000000100000 : "u-boot"
0x000000100000-0x000000600000 : "kernel"
0x000000600000-0x000000700000 : "dtb"
0x000000700000-0x000001000000 : "file system"
Fixed MDIO Bus: probed
Intel(R) PRO/1000 Network Driver - version 7.3.21-k5-NAPI
Copyright (c) 1999-2006 Intel Corporation.
e1000e: Intel(R) PRO/1000 Network Driver - 1.0.2-k2
e1000e: Copyright (c) 1999 - 2009 Intel Corporation.
cpu6/6: > WARNING (FM-PCD) [drivers/net/dpa/NetCommSw/Peripherals/FM/Pcd/fm_kg.c:1644 KgConfig]:
cpu6/6: numOfSchemes was defined 0 by user, re-defined by driver to FM_PCD_KG_NUM_OF_SCHEMES
cpu6/6:
cpu6/6:
Freescale FM module (Jan 28 2011:22:25:00)
cpu6/6: fsl_mac: FSL FMan MAC API based driver ()
cpu6/6: fsl_mac: ffe4e2000.ethernet: FMan dTSEC version: 0x08240101
cpu6/6: fsl_mac: ffe4e2000.ethernet: FMan MAC address: 00:04:9f:01:71:f4
cpu6/6: Applying 10G tx-ecc error workaround (FMAN11) ...
cpu6/6: done.
cpu6/6: fsl_mac: ffe5f0000.ethernet: FMan XGEC version: 0x0001032c
cpu6/6: fsl_mac: ffe5f0000.ethernet: FMan MAC address: 00:04:9f:01:71:fc
cpu6/6: fsl_dpa: FSL DPAA Ethernet driver ()
cpu6/6: fsl_dpa: ethernet.25: dpaa_eth.c:1740:dpa_bp_create() eth%d: Using private BM buffer pools
cpu6/6: Using dynamic RX QM frame queues
cpu6/6: Using dynamic TX QM frame queues
cpu6/6: fsl_dpa: ethernet.33: dpaa_eth.c:1740:dpa_bp_create() eth%d: Using private BM buffer pools
cpu6/6: fsl_oh: FSL FMan Offline Parsing port driver ()
fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
fsl-ehci fsl-ehci.0: irq 44, io base 0xffe210000
fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
fsl-ehci fsl-ehci.1: can't setup
fsl-ehci fsl-ehci.1: USB bus 2 deregistered
fsl-ehci fsl-ehci.1: init fsl-ehci.1 fail, -110
fsl-ehci: probe of fsl-ehci.1 failed with error -110
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Initializing USB Mass Storage driver...
USB Mass Storage support registered.
rtc-ds3232 1-0068: rtc core: registered ds3232 as rtc0
EDAC MC: Ver: 2.1.0 Jan 28 2011
Freescale(R) MPC85xx EDAC driver, (C) 2006 Montavista Software
EDAC PCI0: Giving out device to module 'MPC85xx_edac' controller 'mpc85xx_pci_err': DEV 'ffe200000.pcie' (INTERRUPT)
MPC85xx_edac acquired irq 16 for PCI Err
MPC85xx_edac PCI err registered
EDAC PCI1: Giving out device to module 'MPC85xx_edac' controller 'mpc85xx_pci_err': DEV 'ffe202000.pcie' (INTERRUPT)
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
mmc0: SDHCI controller on ffe114000.sdhc [ffe114000.sdhc] using DMA
caam ffe300000.crypto: device ID = 0x0a10020000000000
caam ffe300000.crypto: job rings = 4, qi = 1
alg: No test for authenc(hmac(sha1),cbc(aes)) (authenc-hmac-sha1-cbc-aes-caam)
caam ffe300000.crypto: authenc-hmac-sha1-cbc-aes-caam
alg: No test for authenc(hmac(sha256),cbc(aes)) (authenc-hmac-sha256-cbc-aes-caam)
caam ffe300000.crypto: authenc-hmac-sha256-cbc-aes-caam
alg: No test for authenc(hmac(sha1),cbc(des3_ede)) (authenc-hmac-sha1-cbc-des3_ede-caam)
caam ffe300000.crypto: authenc-hmac-sha1-cbc-des3_ede-caam
alg: No test for authenc(hmac(sha256),cbc(des3_ede)) (authenc-hmac-sha256-cbc-des3_ede-caam)
caam ffe300000.crypto: authenc-hmac-sha256-cbc-des3_ede-caam
alg: No test for authenc(hmac(sha1),cbc(des)) (authenc-hmac-sha1-cbc-des-caam)
caam ffe300000.crypto: authenc-hmac-sha1-cbc-des-caam
alg: No test for authenc(hmac(sha256),cbc(des)) (authenc-hmac-sha256-cbc-des-caam)
caam ffe300000.crypto: authenc-hmac-sha256-cbc-des-caam
fsl-pme ffe316000.pme: ver: 0x00100201
sample_db: starting pme2 sample DB initialisation
sample_db: db for pme ver 2.1 or greater
sample_db: pme2 sample DB initialised
Freescale pme2 db driver
Freescale pme2 scan driver
fsl-pme2-scan: device pme_scan registered
IPv4 over IPv4 tunneling driver
GRE over IPv4 tunneling driver
TCP cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 10
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 15
rtc-ds3232 1-0068: hctosys: unable to read the hardware clock
RAMDISK: gzip image found at block 0
VFS: Mounted root (ext2 filesystem) on device 1:0.
Mounting /proc and /sys
Starting the hotplug events dispatcher udevd
Synthesizing initial hotplug events
Setting the hostname to p4080
Mounting filesystems
Starting syslogd and klogd
Running sysctl
Setting up networking on loopback device:
Warning: no IPADDR is set, please set this from the ltib
config screen, or directly in /etc/rc.d/rc.conf.
IP address setup bypassed
Starting inetd:
Starting the port mapper:
Starting the dropbear ssh server:
Starting the boa webserver:
        Welcome to the LTIB Embedded Linux Environment
!!!!! WARNING !!!!!!!
The default password for the root account is: root
please change this password using the 'passwd' command
and then edit this message (/etc/issue) to remove this message
p4080 login:
--------u-boot---------
printenv
baudrate=115200
bdev=sda3
bootcmd=run flashboot
bootdelay=10
bootfile=uImage
c=ffe
consoledev=ttyS0
eth10addr=00:04:9F:01:71:FE
eth10addr=00:04:9F:01:71:FD
eth1addr=00:04:9F:01:71:F4
eth2addr=00:04:9F:01:71:F5
eth3addr=00:04:9F:01:71:F6
eth4addr=00:04:9F:01:71:F7
eth5addr=00:04:9F:01:71:F8
eth6addr=00:04:9F:01:71:F9
eth7addr=00:04:9F:01:71:FA
eth8addr=00:04:9F:01:71:FB
eth9addr=00:04:9F:01:71:FC
ethact=FM1@DTSEC2
ethaddr=00:04:9F:01:71:F3
fdtaddr=c00000
fdtfile=p4080ds/p4080ds.dtb
fileaddr=100000
filesize=319CB8
flashboot=setenv bootargs root=/dev/sda3 rw console=ttyS0,115200 ; bootm e8020000 e9300000 e8800000
gatewayip=192.168.100.0
hwconfig=fsl_ddr:addr_hash=true,ctlr_intlv=cacheline,bank_intlv=cs0_cs1_cs2_cs3
ipaddr=192.168.100.250
loadaddr=1000000
netdev=eth0
nfsboot=setenv bootargs root=/dev/nfs rw nfsroot=$serverip:$rootpath ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off console=$consoledev,$baudrate $othbootargs;tftp $loadaddr $bootfile;tftp $fdtadr
norbootaddr=e8020000
nordtbaddr=e8800000
norramdiskaddr=e9300000
ramboot=setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr
ramdiskaddr=2000000
ramdiskfile=p4080ds/rootfs.ext2.gz.uboot
remoteboot=setenv bootargs root=/dev/sda3 rw console=ttyS0,115200 ; bootm 1000000 e9300000 e8800000
rootpath=/opt/nfsroot
serverip=192.168.100.22
stderr=serial
stdin=serial
stdout=serial
tftpflash=tftpboot $loadaddr $uboot && protect off $ubootaddr +$filesize && erase $ubootaddr +$filesize && cp.b $loadaddr $ubootaddr $filesize && protect on $ubootaddr +$filesize && cmp.b $loadaddr $ubootaddr $fe
uboot=u-boot.bin
Environment size: 1920/8188 bytes
mattsm
Have you considered using the latest SDK?
-M
leonidravich
Ok now I am using the last SDK but yet no link ;
U-Boot 2011.09 (Sep 12 2012 - 19:44:26)
   CCB:599.994 MHz,
   FMAN1: 449.996 MHz
   FMAN2: 449.996 MHz
   PME:   299.997 MHz
L1:D-cache 32 kB enabled
36-bit Addressing
I2C:   ready
SPI:   ready
Detected UDIMM HMT125U7BFR8C-H9
CS2 is disabled.
CS3 is disabled.
CS2 is disabled.
CS3 is disabled.
2 GiB left unmapped
4 GiB (DDR3, 64-bit, CL=8, ECC on)
POST memory PASSED
Flash: 128 MiB
L2:128 KB enabled
SRIO1: disabled
SRIO2: disabled
MMC:  FSL_ESDHC: 0
EEPROM: NXID v0
PCIe1: Bus 00 - 00
PCIe2: disabled
PCIe3: Bus 01 - 01
In:serial
Out:   serial
Err:   serial
Net:   Fman1: Uploading microcode version 106.2.0
Fman2: Uploading microcode version 106.2.0
   Image Name:   Linux-3.0.34-rt55-02404-g1a39570
   Data Size:3699391 Bytes = 3.5 MiB
   Image Name:   fsl-image-minimal-p4080ds-201209
   Data Size:4694844 Bytes = 4.5 MiB
   Loading Ramdisk to 2fb85000, end 2ffff33c ... OK
   Loading Device Tree to 03fe1000, end 03fffc05 ... OK
Memory CAM mapping: 256/256/256 Mb, residual: 3328Mb
Linux version 3.0.34-rt55-02404-g1a39570 (leonid@Leonid2) (gcc version 4.6.2 (GCC) ) #1 SMP Sun Sep 23 11:53:52 IST 2012
Found initrd at 0xefb85000:0xeffff33c
No /soc@ffe000000/qman@318000 property 'fsl,qman-fqd', using memblock_alloc(0000000000200000)
No /soc@ffe000000/qman@318000 property 'fsl,qman-pfdr', using memblock_alloc(0000000001000000)
Qman ver:0a01,01,01
No /soc@ffe000000/bman@31a000 property 'fsl,bman-fbpr', using memblock_alloc(0000000001000000)
Bman ver:0a02,01,00
pme: No /soc@ffe000000/pme@316000 property 'fsl,pme-pdsr', using memblock_alloc(0x0000000001000000)
pme: No /soc@ffe000000/pme@316000 property 'fsl,pme-sre', using memblock_alloc(0x0000000000a00000)
No USDPAA memory, no 'usdpaa_mem' bootarg
setup_arch: bootmem
PCI host bridge /pcie@ffe200000 (primary) ranges:
/pcie@ffe200000: Setup 64-bit PCI DMA window
/pcie@ffe200000: DMA window size is 0xdf000000
/pcie@ffe202000: Setup 64-bit PCI DMA window
/pcie@ffe202000: DMA window size is 0xdf000000
arch: exit
Zone PFN ranges:
  Normal   empty
  HighMem  0x00030000 -> 0x00100000
0: 0x00000000 -> 0x00100000
PERCPU: Embedded 10 pages/cpu @c27fa000 s18624 r8192 d14144 u40960
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1040384
Kernel command line: root=/dev/ram rw console=ttyS0,115200
Placing 64MB software IO TLB between c3ff2000 - c7ff2000
software IO TLB at phys 0x3ff2000 - 0x7ff2000
Memory: 4019808k/4194304k available (7296k kernel code, 174496k reserved, 220k data, 566k bss, 288k init)
  * 0xfff5f000..0xfffff000  : fixmap
    RCU debugfs-based tracing is enabled.
NR_IRQS:512 nr_irqs:512 16
Brought up 8 CPUs
xor: measuring software checksum speed
   8regs :  1349.000 MB/sec
   8regs_prefetch:  1176.000 MB/sec
   32regs:  1274.000 MB/sec
   32regs_prefetch:  1152.000 MB/sec
xor: using function: 8regs (1349.000 MB/sec)
fsl-of-pamu fsl-of-pamu.0: implementing work-around for erratum A-004510
MPC85xx_edac acquired irq 494 for PCI Err
MPC85xx_edac acquired irq 492 for PCI Err
pci 0000:00:00.0:   bridge window [io  0x0000-0xffff]
pci 0001:02:00.0:   bridge window [io  0xfffee000-0xffffdfff]
raid6: int32x1250 MB/s
raid6: int32x2404 MB/s
raid6: int32x4534 MB/s
raid6: int32x8360 MB/s
raid6: using algorithm int32x4 (534 MB/s)
vgaarb: loaded
Bman portals initialised
Bman: BPID allocator includes range 32:32
Qman portals initialised
Qman: FQID allocator includes range 256:256
Qman: CGRID allocator includes range 0:256
Qman: pool channel allocator includes range 33:15
Switched to NOHz mode on CPU #5
Switched to NOHz mode on CPU #7
Switched to NOHz mode on CPU #1
Switched to NOHz mode on CPU #4
Switched to NOHz mode on CPU #0
Switched to NOHz mode on CPU #3
Switched to NOHz mode on CPU #6
Switched to NOHz mode on CPU #2
TCP reno registered
RPC: Registered named UNIX socket transport module.
Freeing initrd memory: 4588k freed
type=2000 audit(1.404:1): initialized
HugeTLB registered 4 MB page size, pre-allocated 0 pages
HugeTLB registered 16 MB page size, pre-allocated 0 pages
HugeTLB registered 64 MB page size, pre-allocated 0 pages
HugeTLB registered 256 MB page size, pre-allocated 0 pages
HugeTLB registered 1 GB page size, pre-allocated 0 pages
NTFS driver 2.1.30 [Flags: R/O].
msgmni has been set to 1204
async_tx: api initialized (async)
ePAPR hypervisor byte channel driver
brd: module loaded
loop: module loaded
Freescale USDPAA process driver
fsl-usdpaa: no region found
st: Version 20101219, fixed bufsize 32768, s/g segs 256
fe8000000.flash: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000001 Chip ID 0x002801
  Amd/Fujitsu Extended Query version 1.3.
fsl_espi ffe110000.spi: at 0xf117a000 (irq = 53)
e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
e1000: Copyright (c) 1999-2006 Intel Corporation.
e1000e: Intel(R) PRO/1000 Network Driver - 1.3.10-k2
e1000e: Copyright(c) 1999 - 2011 Intel Corporation.
FMAN(0) Fifo size settings:
  - Total buffers available(512 - 256B/buffer)
  - Total throughput(1Gbps)
  - Max frame size(1522B)
  - 1G ports TX 1(12 bufs set (min: 12))
  - 1G ports RX 1(460 bufs set (min: 14))
  - OH-HC ports 4(6)
  - Shared extra buffers(16)
FMAN(0) open dma settings:
  - Total open dma available(32)
  - 1G ports TX 1(14)
  - 1G ports RX 1(14)
  - OH-HC ports 4(1)
  - Shared extra open dma(0)
FMAN(0) Tnums settings:
  - Total Tnums available(128)
  - 1G ports TX 1(59)
  - 1G ports RX 1(59)
  - OH-HC ports 4(2)
  - Shared extra tnums(2)
FMAN(1) Fifo size settings:
  - Total throughput(10Gbps)
  - 10G ports TX 1(18 bufs set (min: 18))
  - 10G ports RX 1(438 bufs set (min: 14))
  - OH-HC ports 4(6)
  - Shared extra buffers(32)
FMAN(1) open dma settings:
  - 10G ports TX 1(8)
  - 10G ports RX 1(8)
  - OH-HC ports 4(1)
  - Shared extra open dma(8)
FMAN(1) Tnums settings:
  - 10G ports TX 1(56)
  - 10G ports RX 1(56)
  - OH-HC ports 4(2)
  - Shared extra tnums(8)
Freescale FM module (Sep 23 2012:11:45:13)
Freescale FM Ports module (Sep 23 2012:11:45:17)
cpu7: fsl_mac: FSL FMan MAC API based driver ()
cpu7: fsl_mac: ffe4e0000.ethernet: FMan dTSEC version: 0x08240101
cpu7: fsl_mac: ffe4e0000.ethernet: FMan MAC address: 00:04:9f:01:71:f3
cpu7: fsl_mac: ffe4e2000.ethernet: FMan dTSEC version: 0x08240101
cpu7: fsl_mac: ffe4e2000.ethernet: FMan MAC address: 00:04:9f:01:71:f4
cpu7/7: Applying 10G tx-ecc error workaround (10GMAC-A004) ...
cpu7/7: done.
cpu7: fsl_mac: ffe5f0000.ethernet: FMan XGEC version: 0x0001032c
cpu7: fsl_mac: ffe5f0000.ethernet: FMan MAC address: 00:04:9f:01:71:fc
cpu7: fsl_dpa: FSL DPAA Ethernet driver ()
cpu7: fsl_dpa: ethernet.14: Using private BM buffer pools
cpu7: Using dynamic RX QM frame queues
cpu7: Using dynamic TX QM frame queues
TX Unit Test using FQ 274
Tested 18848/18848 packets. 0 failed
cpu7: fsl_dpa: ethernet.15: Using private BM buffer pools
cpu7: fsl_oh: FSL FMan Offline Parsing port driver ()
fsl-of-dma ffe100300.dma: dma channel dma-uio0-0 initialized
fsl-of-dma ffe100300.dma: dma channel dma-uio0-1 initialized
fsl-of-dma ffe100300.dma: dma channel dma-uio0-2 initialized
fsl-of-dma ffe100300.dma: dma channel dma-uio0-3 initialized
fsl-of-dma ffe101300.dma: dma channel dma-uio1-0 initialized
fsl-of-dma ffe101300.dma: dma channel dma-uio1-1 initialized
fsl-of-dma ffe101300.dma: dma channel dma-uio1-2 initialized
fsl-of-dma ffe101300.dma: dma channel dma-uio1-3 initialized
/soc@ffe000000/usb@210000: Invalid 'dr_mode' property, fallback to host mode
fsl-ehci fsl-ehci.0: irq 44, io mem 0xffe210000
mpc-i2c ffe118100.i2c: timeout 1000000 us
rtc-ds3232 0-0068: rtc core: registered ds3232 as rtc0
mpc-i2c ffe118000.i2c: timeout 1000000 us
mpc-i2c ffe119000.i2c: timeout 1000000 us
mpc-i2c ffe119100.i2c: timeout 1000000 us
md: raid6 personality registered for level 6
md: raid5 personality registered for level 5
md: raid4 personality registered for level 4
EDAC MC: Ver: 2.1.0
EDAC MC0: Giving out device to 'MPC85xx_edac' 'mpc85xx_mc_err': DEV mpc85xx_mc_err
MPC85xx_edac acquired irq 502 for MC
MPC85xx_edac MC err registered
EDAC MC1: Giving out device to 'MPC85xx_edac' 'mpc85xx_mc_err': DEV mpc85xx_mc_err
MPC85xx_edac acquired irq 501 for MC
caam ffe300000.crypto: fsl,sec-v4.0 algorithms registered in /proc/crypto
platform ffe301000.jr: registering rng-caam
USDPAA portal initialised, bman-uio-1
USDPAA portal initialised, bman-uio-0
USDPAA portal initialised, qman-uio-1
USDPAA portal initialised, qman-uio-0
USDPAA portal layer loaded
Registering the dns_resolver key type
rtc-ds3232 0-0068: setting system clock to 2012-10-19 14:03:21 UTC (1350655401)
md: Skipping autodetection of RAID arrays. (raid=autodetect will force)
Freeing unused kernel memory: 288k freed
INIT: version 2.88 booting
Starting udevudev[903]: renamed network interface eth0 to fm1-gb1
udev[911]: renamed network interface eth1 to fm2-10g
Starting Bootlog daemon: bootlogd: cannot allocate pseudo tty: No such file or directory
bootlogd.
Configuring network interfaces... ifup: don't seem to have all the variables for eth0/inet
done.
Running postinst /etc/rpm-postinsts/100...
INIT: Entering runlevel: 5ostins
Starting syslogd/klogd: done
Stopping Bootlog daemon: bootlogd.
Yocto (Built by Poky 6.0) 1.1 p4080ds ttyS0
Please help
mattsm
What did you update? Did you update your RCW as well? It looks different than the working scenario Brian posted below.
-M
leonidravich
I tried  Brian's RCW without success,
I also updated ramdisk, kernel, u-boot and Fman microcode
.... no link on PC phy
mattsm
I would contact support@freescale.com.
-M
leonidravich
Thanks I will try SDK 1.2
leonidravich
I have same problem, using freescale xaui ethernet 10g daughter board  .
I got the interface in linux but no ping ,
some one can help?
Leonid
