Hi all,
I'm working on the TWR-K60N512 tower, in the gettings started pdf, I read about the TWR-K60N512 board.
Core Clock 96 MHz
Bus Clock 48 MHz
However on both the TWR-K60N512 board and the TWR-SER board there are 50Mhz oscilators.
How do the external oscillator frequecies correspond to the Core and Bus frequencies?
Greetings,
Solved! Go to Solution.
Hi Skyhawk,
Please check this document : K60 Reference Manual chapter 5 Clock distribution. There are located clocking diagram, clock definitions and internal clock requirements.
MartinK
Hi Skyhawk,
MartinK
