I tried Ltib installation for Building my own images for IMX53 sabre board..
but my Ltib compilation is failing.
and the log message generated in host_config.log is
rpmdb: --force-debian: unknown option
Died at ./ltib line 2340.
traceback:
main::setup_rpmdb:2340
main::check_rpm_setup:2403
main::host_checks:1423
main:542
Vj
Solved! Go to Solution.
hi _ttt_
that was me who encountered with problem. and u r reffering to my site & moreever I followed many sites and created a patch. nothing great of me
VJ
same here with Kubuntu 11.10 ... what should we do? is it easier to compile on cygwin? Propably not.
i found a partial solution on following site
http://vijay496.blogspot.in/2012/03/ltib-for-ubuntu-1110-error-faced.html many problems are solved by this great VJ guy. just download his file and good to go.
unfortunately I discovered new problems regarding wget. got following error
These packages failed to build:
wget
has anybody the same problem? what is the output of your wget --version?
besides version I get strange hints on how to compile wget? maybe thats the cause
regards, matthias
Did you ever get this problem solved?
I am having the same issue.
i.e. I am having wget package failing.
Any ideas, thanks?
Ad.
gcc -O2 -Wall -Wno-implicit -o wget cmpt.o connect.o convert.o cookies.o ftp.o ftp-basic.o ftp-ls.o ftp-opie.o hash.o headers.o host.o html-parse.o html-url.o http.o init.o log.o main.o gen-md5.o netrc.o progress.o rbuf.o recur.o res.o retr.o safe-ctype.o snprintf.o gen_sslfunc.o url.o utils.o version.o -lssl -lcrypto -ldl
gen_sslfunc.o: In function `init_ssl':
gen_sslfunc.c.text+0x351): undefined reference to `SSLv2_client_method'
collect2: ld returned 1 exit status
make[1]: *** [wget] Error 1
make[1]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/wget-1.9.1/src'
make: *** [src] Error 2
error: Bad exit status from /home/me/imx53/11.09.01/ltib/tmp/rpm-tmp.33663 (%build)
RPM build errors:
Build time for wget: 21 seconds
Failed building wget
Died at ./ltib line 1380.
traceback:
main::build_host_rpms:1380
main::host_checks:1435
main:542
Started: Mon May 21 00:16:07 2012
Ended: Mon May 21 00:16:28 2012
Elapsed: 21 seconds
wget
Build Failed
hi _ttt_
VJ
hi,
i have the same problem too on ubuntu 11.10
