Sebastian Klaar
Using same project files with CodeWarrior-Eclipse and  Standard-Eclipse
Discussion created by Sebastian Klaar on Feb 28, 2012
Latest reply on Feb 29, 2012 by Sebastian Klaar
I am using the same working directory with CodeWarrior-Eclipse (v10.2) and  Standard-Eclipse.
CodeWarrior does not seem to regard standard eclipse projects as CodeWarrior-Eclipse, although the filenames (.project/.cproject) are the same.
Is it the intention of freescale to have compatible project-files to Standard-Eclipse?
That would be really nice, otherwise the project-files should at least have a different name, to avoid conflicts.
Lets say compatibility is indended:
Whats about different eclipse versions? Have they a compatible project-format to Codewarrior?
How do I merge CodeWarrior and Eclipse project files, so they work with both IDE's?
