Flash security Byte
Flash security Byte
Schani
Hello
When I study NormalDemo code, I find code as below
/* Program the Security Byte in the Flash Configuration Field to an unsecure value */
returnCode = pFlashProgramLongword(&flashSSDConfig, 0x40C, 4, \
(UINT32)(&unsecure_key), pFlashCommandSequence);
if (FTFx_OK != returnCode)
ErrorTrap(returnCode);
It seems to unlock some security function by writing 4 bytes data from 0x40C.
But I can't find any data sheet talked about memory mapping(0x40C).
Could somebody help me ??
Thanks a lot
mjbcswitzerland
Specialist V
The FLASH configuration is described in the Flash memory module. In the K60 user's manual Rev. 5 this is chapter 28.3.1. The Flash configuration parameters are read from address 0x00000400 at reset and its structure is shown below.
typedef struct stKINETIS_FLASH_CONFIGURATION                             // loaded from FLASH 0x00000400 at reset{    unsigned char  ucBackdoorComparisonKey[8];    unsigned char  ucProgramFlashProtection[4];    unsigned char  ucFlashSecurity;    unsigned char  ucNonvolatileOption;    unsigned char  ucEEPROM_protection;    unsigned char  ucDataFlashProtection;} KINETIS_FLASH_CONFIGURATION;
Mark
Schani
Dear Mark
BTW, pFlashProgramLongword function of this code(NormalDemo)
        K60 flash command (FCMD: 0x06) is used,
        But, why can't I find any information described this command at K60 Sub-Family
        Reference Manual Rev. 2, Dec 2011 or any offical documents?
        It just lists FCMD
0x00 Read 1s Block
0x01 Read 1s Section
0x02 Program Check
0x03 Read Resource
0x07 Program Phrase
0x08 Erase Flash Block
0x09 Erase Flash Sector
0x0B Program Section
0x40 Read 1s All Blocks
0x41 Read Once
0x43 Program Once
0x44 Erase All Blocks
0x45 Verify Backdoor Access Key
0x46 Swap Control
0x80 Program Partition
0x81 Set FlexRAM Function
        Do you know any detail information about FCMD: 0x06 command??
        Thank  you..
admin
Specialist II
It looks like your FTFL flash command list is out-of-date.  Here is the latest from rev 6 of the manual.
0x00 Read 1s Block
0x02 Program Check
0x03 Read Resource
0x06 Program Longword
0x07 Program Phrase
0x41 Read Once
0x43 Program Once
0x46 Swap Control
Schani
Dear Mark,
    I got it .
   Thank for your help.:smileyhappy:
Schani
