BeeKit Export and Import into CodeWarrior
Question asked by Chris Rodgers on Feb 20, 2012
Latest reply on Aug 8, 2012 by Han-Joon Kim
I'm trying to work through the BeeKit example from BKWCTKUG.pdf from the following lnk:
http://cache.freescale.com/files/rf_if/doc/user_guide/BKWCTKUG.pdf?fsrch=1&sr=1
I'm using BeeKit 2 and CodeWarrior 10.2 (Special Edition) from the following link:
http://cache.freescale.com/lgfiles/devsuites/MCU/CW_MCU_v10.2_SE.exe?WT_TYPE=IDE%20-%20Debug,%20Compile%20and%20Build%20Tools&WT_VENDOR=FREESCALE&WT_FILE_FORMAT=exe&WT_ASSET=Downloads
As per Section 2.6 on page 35, I'm able to Export the solution.
But when I open CodeWarrior and try to Import (as per Section 2.7.1 on pg. 36) I am unable to do so.
I get the message "No projects found to import"
It doesn't say exactly what type of file it's looking for, but it doesn't find it. I can see that there are .XML files but maybe it's looking for something else?
If I can't import these files into CodeWarrior, I can't load them into my ZigBEE NCB and SRB units for testing.
Any suggestions?
Thanks!
