Bootloader as mass storage device with Linux.
MichaelDavid
We have a problem with the bootloader as USB mass storage device. It works fine with windows and doesn't work well with Linux. Our device is Linux based so we need the solution to work on Linux.
MichaelDavid
The problem was solved.  In the copy process the directing scrip was for FAT32 file type instead of FAT16 used by the bootloader.
MichaelDavid
Problem not solved! could not boot again. the Linux booting still don't work.
Gra67
Michael, did you get any further with this?
We are trying to get the USB mass storage device bootloader demo (AN4379) working on Linux and having mixed results
Graeme
frrescaleDevelo
I am trying to do the same. Have you got anywhere with this yet?
