Hi @all,
in my application PRM file i include bootloader by HEXFILE ..\bin\bootloader.s19 instruction. If i do some small changes in this bootloader.s19 file (f.e. only one var value changed in bootloader project and became recompiled) and copy paste the new file in app folder, and than recompile the app -> the app still works with the old bootloader.s19 file. Compiler don't realizes that the bootloader.s19 file has changed a little bit, and don't refresh it.
How can i teach the compiler to compile the bootloader.s19 each time, by every compilation progress, unless it have changed or not?
Solved! Go to Solution.
For original CodeWarrior
For Eclipse-based CodeWarrior (v10+)
- Ware
- Ware
Thanks, just one click more i would like to have, but it works
