Posted: Thu Jul 07, 2005 2:27 pm
I have e-mailed Metrowerks support and those guys are really quick! Here is their reply:
Quote: |
File fixing the problem is at: ftp://ftp3.metrowerks.com/pub/dropzone/source.wnd-proto-CW12V41-07-jul-05.zip The "source.wnd" file should be replaced (after backup) in "prog" folder of CodeWarrior installation. I cannot guarantee how long this file will remain on FTP server due to the limited storage space. |
I have not tried it yet - can anyone confirm whether the fix works?
Posted: Sat Jul 09, 2005 7:27 pm
I noticed they said they wont host it for long I will mirror it on S12X.com... You think they will make a new release or patch for it? I assume the next release would have the fix built in.
edit - here is the link
http://www.s12x.com/files/source.wnd-proto-CW12V41-07-jul-05.zip
Posted: Mon Jul 11, 2005 2:19 pm
Thanks it works!!
Do you know if there has been any progress with being able to step through code that is defined globally?
Thanks again.
Posted: Tue Jul 12, 2005 1:38 pm
I guess you mean code which is placed into a global address range in the linker file. I am not aware of any fix from Metrowerks for that, we will probably need to wait for the next full release of the tools which I am being told will happen "soon".
