Suppose I would like to remove the U-boot / linux kernel in my application.
In fact, I would like to reuse the U-boot source code as a skeleton for my software ,
for a platform very similar to MPC8308RDB ...
The U-boot source code from sourceforge seems not up to date , and not customized for the MCP8308 ...
I suppose that Freescale engineer have adapted their code for the RDB ... How can I get the last version of the source code?
Thank you
Might you be better off using U-Boot as your bootloader, then developing your application as a binary that can be loaded by U-Boot? That would retain the flexibility of U-Boot in terms of being able to load your app over the network for development, using U-Boot to load your app into flash, etc. U-Boot isn't just for Linux.
