Ruth Hendrix
irda stack
Discussion created by Ruth Hendrix Employee on Jan 26, 2006
This message contains an entire topic ported from a separate forum. The original message and all replies are in this single message. We have seeded this new forum with selected information that we expect will be of value to you as you search for answers to your questions.
Posted: Thu May 12, 2005 2:30 am
hello:
i'm using the mc9s12e128 which has an irda modulator on the serial ports. everything works as advertized, however i need to write a stack for everything from the physical layer to the ircomm layer including irlap and irlmp. has anyone ventured down this path with this chip?
regards,
Posted: Thu May 12, 2005 11:14 am
You can get one here http://www.whitebream.com/s131.shtml but its not free. Sad
Posted: Thu May 12, 2005 6:50 pm
hi:
thanks for your reply!
not free is an understatment! 1500 euros translated into canadian pesos (loonies) is a big chunk. i only need the ircomm portion and was trying to avoid paying for all the other stack features (as well as code size) that i don't require. i guess it's time to roll up the sleeves and start coding.
thanks again!!
regards,
Posted: Thu May 12, 2005 9:47 pm
Why don't you drop them a line, and ask for a quote for just the bit you want, and plead poverty, if you don't ask you won't get.
Posted: Fri May 13, 2005 6:20 pm
hi:
i never even thought of that!
thanks
Posted: Tue May 24, 2005 2:22 pm
You can try to port(from AVR GCC to CodeWarior) PicoIrda stack from Blaulogic
http://blaulogic.com/pico_irda.shtml
regards,
Posted: Wed May 25, 2005 5:57 pm
hi:
thanks for the direction!
regards,
