pavel pindora
M52259Demo MQX_3_7 - Flash Programmer: The Debugger can not write to memory
Discussion created by pavel pindora on Jan 7, 2012
Latest reply on Jan 13, 2012 by pavel pindora
Configuration:
Win 7 Prof
CodeWarior 7.2 Eval.  + Patch 722
Project MQX + MFS (I also tested "only MQX")
Flash Programer :
52259 / Coldfire v2-v4 JM60 OSBDM
Target inic ...ColdFire_Support\Initialization_Files\M52259DEMO.cfg
Erase Flash  :  Erase Command Succeeded
Blank Check Completed Successfully
Program/Verify
...MQX_3_7Test_MFS\output\intflash_d.elf.S19
Program
Downloading 0x00010000 bytes to be programmed at 0x00000420
How to ?
Thank Pavel
