Ruth Hendrix
Cheap BDM tool
Discussion created by Ruth Hendrix Employee on Jan 24, 2006
This message contains an entire topic ported from a separate forum. The original message and all replies are in this single message. We have seeded this new forum with selected information that we expect will be of value to you as you search for answers to your questions.
Posted: Sun Sep 05, 2004 9:09 pm
What is the cheapest evaluation board with built in BDM (with either RS232 or USB pc interface) avaiable and where can you buy it.
Posted: Sun Sep 12, 2004 1:58 am
I give up.
But I got a free hs12 dev board from Future electronics that
can be used as a pod. What I would really like is a cheap
compilier. Smile
Posted: Thu Nov 04, 2004 6:11 pm
Metrowerks copiler is free up to 8k of code (or somewhere thereabout) - you just need to register
Posted: Fri Nov 05, 2004 10:36 am
To say the truth Metrowerks CodeWarrior for HC(S)12 Special Edition is 12KB code-size limited, it just requires to register in Metrowerks' web site.
Posted: Wed Nov 10, 2004 6:32 pm
I have had great results with the P&E Multilink USB pod for the HCS12 devices. And - the same tool works with the HCS08 family as well.
Posted: Tue Nov 23, 2004 8:06 am
You could always check out the POD from Technological Arts.
http://www.technologicalarts.com/myfiles/ubdm12.html
They also have great evaluation boards.
Although, I still recommend the Noral Flex Debugger... I wouldn't trade it in for anything!
Posted: Sat Jan 22, 2005 7:26 pm
Quote:
I give up.
compilier. Smile
Did you look at GNU GCC port for the HC11/12/S12 ?
http://m68hc11.serveftp.org/
