Is there a simple way to load images from another type of flash device without having to copy them to local flash? If I had some images on an sd card, usb, or some other serial flash, how can I load these as I need them without declaring them as part of the screen before hand?
Solved! Go to Solution.
the new version (not released yet) support external bitmap *.BMP file.
You can look at it in this thread:
https://community.freescale.com/message/100414#100414
Petr
Petr
