Greg Lawson
Output s-record for external memory
Discussion created by Greg Lawson on Jan 3, 2012
Latest reply on Jan 5, 2012 by Greg Lawson
I have some working code that supports an external EEPROM which is mapped in the PRM file with an address outside the range of the 9S12XS.  The starting address of this space is defined as 0x400000.
What I need to do is generate an s-record for this space.  The map file shows the variables allocated to this space, but I don't know if the abs file contains this space.   And if it does, how do I extract it using the burner file.
