graphic LCD interfacing
donw
Hi all
has anyone tried connecting one of the graphic LCD modules from KENTEC, such as K350QVG-V2-F
 to a S908 micro (using the port lines to generate data lines. WR, CS,  of course) ?
The driver IC HX8347-D docs are hard to follow (asian!)...
I don't need fast grahics (text only), so update speed should not be a problem.
TurboBob
not yet, but the next project in the pipeline will most likely have a small graphical LCD or OLED. Once I get started, I'll post back.
Bob
