Newbie question:
I'm using the K60N512 board under IAR 6.21.
I've gotten several MQX supplied examples to run out of the box (for example, mqx/examples/tfs). When I load up the app and start the debugger, the app starts at the mqx_main function.
However, simply moving the tfs directory elsewhere and changing the include and linker paths in IAR results in the app starting with the main: label. It doesn't appear to start MQX at all.
I'm sure there's an easy fix, but it's evaded me for some time. Help?
Mark Miller
Solved! Go to Solution.
Hi Chalkboard,
this could be helpfull for you how to create your own project, there's document attached in second post.
https://community.freescale.com/thread/94698
Back to your issue, I don't see any problem you possibly could have if it compiled and linked properly. I can't run IAR at the moment, got some issues with a computer :smileyhappy:
There is MQX plugin, you can check many information about MQX as task, memory , etc.
MartinK
Hi Chalkboard,
MartinK
