Hi. I'm using Codewarrior 10.1 with the lastest update, MQX 3.7 and
Kwikstik Patch. (I have a Kwikstik REV 4)
I'm trying to use the MQX example relative to ADC converter, but it not work correctly. The various printf in the example doesn't work.
If I make a Debug, it blocks after a printf (where I set a breakpoint). Exactly in io_read.c in this part of the code.
#if MQX_CHECK_ERRORS
if (dev_ptr->IO_READ == NULL) {
file_ptr->ERROR = MQX_IO_OPERATION_NOT_AVAILABLE;
return(IO_ERROR);
} /* Endif */
#endif
Can you give me a solution?
Solved! Go to Solution.
Hi. I have already resolved this problem, commenting out line 75 of "fio.h" and recompiling PSP and BSP.
Happy Critsmas! :smileyhappy:
Hi alexdev83,
i would like to help you, but i might miss some details. It is hard to understand what you are having difficulties with.
What's your user_config and are u playing with ADC example for kwikstik or you modified it ?
