Data flash driver
Data flash driver
Teckna
Contributor V
I know that MQX 3.8 is going to be released in few days. Is there any rumors about the MFS data flash driver?
I'm using AT45DB161D data flash on which I want to put a file system and this driver would be much useful.
Many thanks
Teckna
c0170
Senior Contributor III
Hi Teckna,
Negative answer. There is no data flash driver in MQX 3.8.
MartinK
c0170
Hi Teckna,
MartinK
Teckna
Contributor V
Hi Martin,
What about data flash driver in the upcoming MQX 4.0?
Many thanks
Teckna
JuroV
There is nandflash driver with wear leveling functionality in MQX 4.0 AFAIK.
BryGuyH
I've been looking for it in the MQX 4.0 release and can't seem to find it. I've gone through all the K60/K70 projects and haven't seen anything jump out at me regarding a wear leveling module present. Can you point me in the right direction?
JuroV
Hi Bryant,
excuse me for misinformation. I was informed that the package will be released soon separately for MQX 4.0
markusp
This separate package - are you referring to the Embedded Access's SFFS add-on, or will there be another, free package added to the MQX 4.0? When it will be released?
Br,
Markus
JuroV
I asked for an information why it was still not released. The reply was that you should ask Freescale's customer support to get status of this package.
It is NOT the one from Embedded Access.
Teckna
Contributor V
Is there any plan to develope such driver in the future release of MQX?
Many thanks
Teckna
