Graham Naylor
Simultaneous assembly of HC12 and XGATE instructions
Discussion created by Graham Naylor on Nov 29, 2011
Latest reply on Dec 5, 2011 by Graham Naylor
I'm working on a project using Absolute Assembly and would like to make use of the XGATE co-processor.
The XGATE routine I have in mind is fairly simple and I can write it in such a way that it is relocatable so can be copied into RAM and executed from there.
Is it possible to get Code Warrior 5.9.0 to assemble both HC12 and XGATE instructions in the same .asm file?
