Markus Forrer
S12X Flash write access
Discussion created by Markus Forrer on Nov 23, 2011
Latest reply on Dec 7, 2011 by Markus Forrer
I implemented the flash routines for the S12 and it works fine.
Now I have a new project with HCS12XEP and have to adapt the flash routines. Is it correct that I can write to a flash block while code fetching from a different flash block? Or is it the same like S12 (flash routines in RAM and no IRQ while flash access)? I didn't find an answer in the datasheet.
Thanks!
Mark
