Hi Team,
I am working on Imx8MQ EVK. I want to port Android 10 on this target. From what branch I can download AOSP ? Where default images available?
Rajendra
see the following steps, please!
1. Download the android document
https://www.nxp.com/design/software/embedded-software/i-mx-software/android-os-for-i-mx-applications...
Choose the android version you need, then download the document, and unzip it, you can see the Android_User's_Guide.pdf file, we will use it.
2. Download android BSP source
Choose the android BSP version you want to use and download it.
3. Download android source code
Download and compile android image according to the steps described in Android_User's_Guide.pdf.
Have a nice day!
B.R,
weidong
1. I found so many revisions under https://source.android.com/setup/start/build-numbers#source-code-tags-and-builds. out of that, What Android revision support's iMx8 mq evk?
2.By default I am downloading AOSP? How to add my target iMx8mq EVK?
