iMX8 Android Build Windows SDK error
1,058 次查看
mt_android
I have iMX8 MEK board with Android 11 downloaded. By following the "Android User Guide", I build the android successfully. Then, I try to build Windows SDK by running "make win_sdk", and encounter some errors. Here is the log:
[ 82% 2738/3336] //tools/tradefederation/core:tradefed-docs doclava [linux_glibc common]
out/soong/.intermediates/tools/tradefederation/core/tradefed-docs/linux_glibc_common/srcjars/com/android/tradefed/build/BuildInfo.java:78: error: cannot find symbol
public Map<String,String> getBuildAttributes() { throw new RuntimeException("Stub!"); }
symbol: class Map
out/soong/.intermediates/tools/tradefederation/core/tradefed-docs/linux_glibc_common/srcjars/com/android/tradefed/build/BuildInfo.java:86: error: cannot find symbol
public Set<BuildInfoProperties> getProperties() { throw new RuntimeException("Stub!"); }
symbol: class Set
out/soong/.intermediates/tools/tradefederation/core/tradefed-docs/linux_glibc_common/srcjars/com/android/tradefed/build/BuildInfo.java:102: error: cannot find symbol
public void addBuildAttributes(Map<String,String> buildAttributes) { throw new RuntimeException("Stub!"); }
symbol: class Map
out/soong/.intermediates/tools/tradefederation/core/tradefed-docs/linux_glibc_common/srcjars/com/android/tradefed/build/BuildInfo.java:136: error: cannot find symbol
protected Map<String,VersionedFile> getVersionedFileMap() { throw new RuntimeException("Stub!"); }
symbol: class Map
out/soong/.intermediates/tools/tradefederation/core/tradefed-docs/linux_glibc_common/srcjars/com/android/tradefed/build/BuildInfo.java:142: error: cannot find symbol
public Set<String> getVersionedFileKeys() { throw new RuntimeException("Stub!"); }
symbol: class Set
out/soong/.intermediates/tools/tradefederation/core/tradefed-docs/linux_glibc_common/srcjars/com/android/tradefed/build/BuildInfo.java:148: error: cannot find symbol
public File getFile(String name) { throw new RuntimeException("Stub!"); }
symbol: class File
Could anyone please take a look and guide me to solve this issue? Any suggestions would be appreciated.
Thanks a lot.
0 回复数
