I.MX6Q EIM bus Clock Problem
1,586件の閲覧回数
郑焰秋
The iMX6Q chip uses the EIM bus to communicate with the FPGA. When choosing asynchronous communication, the SignalTap of QuartusII software is used on the FPGA side to capture CS, OE, and RW signals. The effective duration of CS signals is not fixed. The device configuration is shown in the following figure
0 返答(返信)
