Hi All,
I try to bring the Wi-Fi on IMX8M Plus, using Azurewave CM276 M.2 card.
My chip version i.MX 8M Plus Evk is A1.
I uploaded the image L5.4.70-2.3.0 imx-image-full.
I execute "modprobe moal mod_para=nxp/wifi_mod_para.conf".
If I execute "wpa_supplicant -d -B -i mlan0 -c /etc/wpa_supplicant.conf -Dnl80211", I get "mlan0: Unsupported driver 'n180211'".
What should I do next? Сan anyone write step by step please?
Hi, Community
I'm trying to connect WiFi on the board iMX8M Plus EVK. OS is Linux 5.10.35_2.0.0 full. The output of ifconfig is givens as a file. However, trying to ping google.com, gives me a mistake: "ping: google.com: Temporary failure in name resolution". Could you show me the approach how to establish a stable WiFi connection...
Thank you!
I have mailed to you and send you my test result, try to get it
Hello @joanxie,
Even I am facing the same problem. I have connected the working ethernet cable to the board but its detecting now. But when I try to install or ping data gets lost. Can you please help me solve this issue.
root@imx8mpevk:~# pip install python3
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffffb6e63670>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/python3/
Thank You.
Kind Regards,
Keniz Gandhi
